Honeywell True Steam blowing up our cond pump
GW
Member Posts: 4,692
Anyone have problems with HW True Steam killing their cond pumps? We must have 20 true steams out there, no pump issues. We have one job we did last summer, 12 GPD, and the thing smoked two pumps. I was thinking of making a make-shift 'holding tank' to slowly drain the water into the pump, allowing it to cool off too.
So, I am wondering if this particular true steam is simply dumping the water either too fast or too hot.
My guy called HW, that was useless.
Thanks, Gary
Thanks, Gary
Hot Steamer
I like the solution you propose. It is inexpensive and easy to maintai.
Good luck,
Tim0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
