To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
water being pulled from boiler
I have a 450 mills smith boiler ,2,500,000,btu 2 pipe condensate pump return that the water is pulled right out of the boiler and going off on low water.
  • Rich_LRich_L Member Posts: 59
    Has this problem just started?
    Has it always done this? If not have there been any changes to your system lately?
    Is it piped properly? You may need to post a few pictures of the boiler and near piping if you're not sure.
    Anything done with your boiler water lately? Could be foaming and priming?
  • crash2009crash2009 Member Posts: 1,484
    edited February 2012
    Need more info
    Just trying to narrow things down a bit.
    Does the water disapear, never to be seen again?  (which would suggest a leak)
    Or, does the water eventually make its way back to the boiler?  (which would suggest pressure too high, or a condensate return problem)
  • Dave in QCADave in QCA Member Posts: 1,650
    more questions
    Does the water suddenly disappear?  Does the system have a condensate tank and pump?  Are there zone valves on any of the steam mains?
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Tim_HodgsonTim_Hodgson Member Posts: 59
    Disappearing water
    I will assume the boiler has worked well in the past and nothing mechanical has been changed. The boiler water has three ways to get out of the boiler: Carryover from dirty water and surface tension, it can back out the bottom of the boiler through a defective check valve at the condensate pump and up the chimney if you have a leak in a section.
    I have had a lot of good results by cleaning the water side of the boiler.
    Good luck,
    Tim
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
