honeywell actuator
chuck172
Member Posts: 90
Does anyone know if I can use a Tekmar Mixing Setpoint Control 153 to control a honeywell M6063 Actuator and V5442 Compact Rotary 4 way Valve?
I don't see why
I don't see why you can't. Any reason why you don't want to use the recommended AQ-675? Should be compatible with any PID control, like Tekmar. I would call Honeywell just to double check.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
