Honeywell XL50 MMI
Zman
Member Posts: 7,569
I am doing some troubleshooting on a building with a Honeywell XL50 MMI controller
I have been unable to access the settings in this system. Is there an inexpensive way to communicate with this system using a laptop? Or do I have to get a honeywell tech on the job.
Albert Einstein
Albert Einstein
What control is
it integrated with? The MMI version allows buswide access to other controllers. It can be used with Honeywell Excel 5000 System or it can be used in an open LonWorks network. Is there a maintenance engineer available0 -
Looking for more info
The controller was installed in the year 2000. It is connected to an old school modem. There have been staff changes in the maintenance department and no one knows anything about the system. What am I looking for to interface? I am very comfortable with boiler/HVAC settings but have no experience with this system.
Thank you in advance"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Find out
who installed the system and get connected with them. I am sure they would be able to identify what you are looking for.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
