TACO 219 3/4"
nubeee
Member Posts: 3
I need to replace a TACO 219 3/4" on my basebord heating ( a 3 zone ) I am not getting heat to one of the zones....pipes are hot up to the point of this valve...then cool beyond it....unlike the other 2 which are hot before and after...my question is can i just replace the "guts" of this withouit having to sweat a new one in? Shutting down the furnace and letting it cool of course then...opening the faucet type valve at the other end....what kind of pressure will there be left in the line?
Taco 219
Is a check valve.
Is the pump that feeds into this valve running?0 -
Taco
The circulator "sounds' like its running...gets hot like the other 2...so ide say yes?0 -
thanks
Appreciate your help....I was able to find the problem....wasnt the valve...0 -
Valve:
It usually isn't.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
