Tekmar 400 series
PeterNH
Member Posts: 88
Hello,
Anyone have a 400 Series House Control?
Or any experience with it?
Pro's Con's
Comments all appreciated.
Peter
Pro's Con's
Peter
It's a typical ORC control.
This control you will like. Offers ORC out door reset control for your boiler with Priority DHW if so desired. Incorporates the use of zoning with zone valves or switch to pump control with the addition of isolation relays to activate pumps. User selectable set points and minimum water temp control. Google Tekmar controls and you can find literature to answer all of your questions.
Mike T.0 -
Reading
Hello Mike,
Thanks. I've spent countless hours reading about all the Tekmar controls.
I've almost convinced myself on the 402, with just a few revervations/ questions. To follow. later.
Just looking for other opinions, good or bad.
Peter0 -
Love Tekmar
Peter,
I have had great experiences with tekmar. The tech support is great.As you in the east would say "they are wicked smaaat"! I have called them several times in the design phase and they have been very useful.
Albert Einstein0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
