Does anyone
Steve_210
Member Posts: 646
Make a storage tank. 3' high x 1' x 1'. Need some extra storage in a tight space.
What for?
What kind of application would this be? If for DHW, perhaps a flat plate heat exchanger would be the ticket.0 -
I have an existing
Indirect, and need some extra storage.0 -
well
That would be about almost a 18 gal. tank uninsulated and involve piping changes. Why don't you crank up the temp of the existing indirect and add a mixing valve to temper the out going water?0 -
Vaughn
I used a couple of their stubby tanks years back. They were either 30-40 gallon tanks. They were great for crawl spaces. I would check into other brands though0 -
Thanks all
I have a GB 142/30, and have tried setting the HW at max. Temporally, but I still run out, just need something to take care of the initial dump. I think I found something that will fit ,
Thanks guys. Will keep you posted.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
