Weil-McLain bulletin AE-8403
Duff
Member Posts: 61
Has anyone got a bulletin put out by weil mcLain AE-8403??? It pretains to "reservoir Pipe" for a steam boiler. It's a 8inch pipe used on a steam return that is very slow. I was curious about the sizing and the recomended piping layout. Thanks
Yes
I have a bulletin that describes what you ask. Not sure if it's exactly what you are looking for. but here it is.0 -
Duff
Thanks crash for your help....stay warm.0 -
Better Reservoir Drawing
Hi- This is the up to date Weil-McLain manual and the detail of the drawing and instructions on page 16 seems to be a bit clearer. Finding an 8 inch threaded pipe nipple may be a bit tough as the biggest I've seen readily available are 6 inch.
As Crash mentioned, I'm not quite sure what you are looking for. If you are getting slow condensate return I would check that your wet return is not clogged up and clean or replace it before thinking about installing a reservoir.
- Rod0 -
thanks for the help
thanks Rod I was just wondering about that reservoir for the next time I'm looking at a job. It's so important to read the manufactures installation guide. I just hate surprizes. Thanks again0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
