To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Governale SunRad radiators
SteveSteve Member Posts: 469
I am planning to use Sun Rad radiators on 2 pipe steam. I have used them many times on 1 pipe, with no problems. But with a full size 1 1/4" valve there is no way for water to get trapped. My concern is, condensate getting trapped in the leg of the Sun Rad and causing water hammer. Especially as 1 of the steam supplies is going to be downfeed of the radiator.
Has anybody used the SunRad on 2 pipe steam? Or should I just stick to GovFree, where I know the condensate can be fully drained. I have no access to the boiler or control over the steam pressure, this is a standard 2 pipe system with steam traps, not a vapor system.
another question; Does anybody still make ecentric bushings? I have often seen them on old radiators, but never used them. As the radiators are small I do not have the room for ecentric couplings.
  • Dave in QCADave in QCA Member Posts: 1,650
    eccentric bushings
    After a 2 year search, I can attest that no one is currently making an eccentric bushing.  Anvil pipe manufactures eccentric couplings.
    If you have a radiator with a steam entering at the top and condensate out at the bottom, you don't need to worry about eccentric fittings, it will work find even with a puddle of condensate at the bottom and it will not hammer.  However, if the steam enters through at the bottom via a valve that is larger than the 1/2 outlet, which is bushed, the water line will end up being higher than the outlet.  The water will try to exit the supply valve.  If the valve is large enough it will work like a one pipe set up and trap will only provide venting, but if it is not, you'll probably wind up with hammering and poor performance.  I would definitely opt for a rad with the supply at the top unless you can figure out how to get an eccentric coupling fit into the space you have.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • SteveSteve Member Posts: 469
    edited January 2012
    With The gov ray
    There are only bottom tappings. Has anybody used them on 2 pipe
    Used Gov free
    Thanks anyway
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
