wirsbo blisters
arne 53
Member Posts: 14
I have inherited a job with Wirsbo 1/2" hePEX sandwiched in a floor between plywood. When we took up a piece of wood the tubing below had numerous blisters, like little bubbles in the pipe, in some areas. The blisters appear to be only on the surface just under a thin layer of some material. We had just put water to the tubing about a week ago and the tubing we could see looked OK. Has anyone ever seen this and should I be worried?
Same issue
with a job I had under 50 psi air for one year, and air pockets were forming under the co-extruded oxygen barrier. I guess the oxygen barriers do work. Also, I've seen pockets on the pipe right out of the box, apparently the co-extruded barrier not adhering properly during mfg., but barrier still in tact.0 -
wirsbo blisters
Is there a time limit for air pressure testing? Mine also was under air pressure for about 9 months. The main question I have is the tubing and oxygen barrier OK, even with the blisters?0 -
we saw the same thing
on a different brand of pipe. shouldn't hurt anything.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
