100% pilot safety
tps
Member Posts: 1
has anyone seen a bi-metal auto re-set pilot safety switch? its on an older gas boiler with live pilot gas . has aga mark, might be wr brand and has a set of contact points that open main burner circuit on loss of pilot and resets when relit.
Baso makes numerous
They're a thermocouple type, but wire in series with the safety train. No pilot(s) no main(s).
http://www.baso.com/lib/subdomain/baso/content/pdfs/4877d2e1c9bd439ca16863a07da7fd76/accessories.pdf?PHPSESSID=9bf1cd2fb20a21b7b2564c157d3e2383
I've not seen any warp switches in a LONG time. I suspect there's a reason...
MEIt's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
