radiator air valve leaking question
tom83
Member Posts: 2
Replace the valve
It's likely time to start replacing all those those little buggers.
Just noticed the piping arangement
Is this a hot water boiler?0 -
reply
Yes, this is a hot water boiler. I am not sure what to replace them with? Thanks.0 -
Are you sure?
I am not a professional, but I never heard of putting steam vent valves on hot water radiators. Also, I would think for a hot water system, there would just be a little coin valve on the radiator, and the supply and return pipes would be on opposite ends of the radiator.
On the other hand, if it is a steam system, that vent valve would be on the opposite end of the radiator from the steam entry pipe and about half way down..0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
