Mixing CI baseboard and fin tube on same system
KAB_2
Member Posts: 15
Due to artistic differences, (yes that's really the reason) we're being asked to mix. Can that be done with different zones, TRV's etc. Thanks guys.
As Long
As they are on different zones sure. You could also run them at different temps but that would depend on each rooms heatloss and the room emmitters capable output. Have plenty of systems running higher temps for fintube and lower temps for cast iron."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
Thank you
Chris -Thanks so much, thought that was the case, appreciate the info.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
