MacDonald Miller Uni-Match Water Feeder
Shuttle
Member Posts: 24
Hello Guys, I am a handy Homeowner. I was checking out my automatic Water feeder; I was wondering if the cap underneath it is used for cleaning? If I shut off the water supply to it, would it be wise to even attempt to clear/Clean it? It is on pretty tight, I did not wanna break the small 1/2 Inch copper pipes serving it?
Question#1 is that brass screw cap for flushing it?
#2 Should I even bother?
The installation is about 5 years old
Unless it gets plugged
I wouldn't open it. There is a strainer in there, but unless it needs cleaning............All Steamed Up, Inc.
Consulting0 -
old saying (nice terms)
"if it aint broke, you cant fix it...but you sure can screw it up"....0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
