To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
testing a main vent
zepfanzepfan Member Posts: 213
what is the best way to tell if a main vent on a two pipe system is plugged up without burning yourself? just slowly unscrew it till you get steam and no air? i need to go look at a steam system on tuesday where the problem is several radiators on the top floor don't get hot and haven't for about ten years.i am suspecting a plugged main vent or too low of pressure.steam systems are very rare in our area.
  • gerry gillgerry gill Member Posts: 2,587
    turn off the system,
    then unscrew the vent, and holding the vent vertical, blow up into it..if your cheeks puff out from backpressure she most likely is no good anymore..if you can easily blow thru it, then it is probably so other issue that is effecting your rads.
    gwgillplumbingandheating.com
  • crash2009crash2009 Member Posts: 1,484
    Shut off the system
      Gerry explained stuck closed, I will attempt to explain stuck open.  Remove the vent.  Turn the vent upside down, keeping it verticle, blow into it.  If air will pass, this is stuck open.  If the vent fails either test, sell them a new one.  For a look at whats inside those vents click on this  http://www.gwgillplumbingandheating.com/webapp/GetPage?pid=610
  • Dave in QCADave in QCA Member Posts: 1,650
    More information needed
    It might be best if you take pictures, make observations, then come back to the wall.
    My first thoughts are that I have never seen nor heard of a steam main getting plugged up.   Also, raising the pressure setting is the sign of an attempt to fix a system that is not working, withouth correcting the actual problem.  Usually, the increased pressue causes more problems than it fixes.  DON"T raise the pressure.  Residential systems operate at 2 PSI max.   Most operate quite well at 0.5 psi.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
