Calling for heat
madmatts
Member Posts: 3
The furnace seems to be receiving a call for heat when the house temp does not warrant the action. Sequence starts up but shuts down almost immediately. Will do this repeatedly. When the need for heat is warrented, system operates fine. Any suggestions for a remedy? I am not by any means an HVAC wizard
Does the boiler
have a tankless coil? That is, does the boiler provide domestic hot water as well as heating hot water?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Calling for heat
forced air not hot water system sorry for not mentioning that earlier0 -
Calling for heat
Thermostat
What type do you have? Sounds like it is no good0 -
Thermostat
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
