gas line test pressure
ChrisJ
Member Posts: 15,592
in Gas Heating
I just installed a new gas line in my house and was told I must pressure test it for the inspector. I have this all set up but am curious about the test pressure.
It seems most guys say to test it at 5 psi. Why is this? Why not go higher, say, 10 - 15 psi? Wouldn't this make finding any leak even a small one faster?
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
testing
Make sure to disconnect your appliances in case a shut off fails. As far as pressures, the black iron can handle any pressure but most use a rogers guage which has a hand pump on it. 5lbs will tell you if there is a leak, although nothing say's you cant test it higher...Dont forget the system only run's on 11" water column (propane)....0 -
Pressure test
I don't know what your inspectors want(hes the boss) but, here in Minneapolis and St. Paul its 25lbs for 24 hours or 100lbs for 1 hour. What ever kind of pipe your using can handle that, or it shouldn't be used.
-Andy0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
