Alternatives to brake cleaner
Fufu
Member Posts: 1
in Oil Heating
Anyone know of a safer alternative to brake cleaner for cleaning nozzle assembly etc? I know breathing in that junk several times a day can't be good for me long term. Thanks!
I use
Hurri Clean from Sids0 -
Alternatives:
It may not be better for you but I have always used PVC cleaner. It is cheap, always available, and comes with a dauber in the can. I always wear nitrile gloves. I keep dirty pint cans and add fresh cleaner from a clean quart can.
If I could find anythng better, I would use it. I haven't found it. Especially for cost.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
