Burnham Freedom 120
Phillyboy
Member Posts: 1
Can anyone help me on this boiler? I fired the boiler up and its running off curve. Its reading an outdoor temp of 78 and has a setpoint temp of 130. According to the curve anything above a 60 degree temp should have a setpoint of 100 degrees.
Im using a tekmar 070 outdoor sensor which has a 10k ohm and used 18 awg wire.
Thanks guys
Thanks guys
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
