what the !***%$#! is this
Mike S_3
Member Posts: 8
anyone have an idea what this is? it is on a steam sysyem in a basement and is connected to the condasate line neat the boiler
It's the main air vent
which works by differential expansion.
This is a Kriebel system. The vent is probably connected to a float trap that closes if water rises into it. The radiators have little check valves called "bafflers" at their outlet connections. The whole system can run on a few ounces pressure- a Vaporstat is a must!
Read about the Kriebel system in chapter 15 of "The Lost Art of Steam Heating".All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
