To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
glycol mixture
when you have a job that has a spec. for a certain glycol mixture,say 30%,does that mean it is 30% pure glycol and 70% water or 30% pure glycol and 70% inhibitors? we normally buy our glycol pre mixed and give the supplier this spec.
  • hot rodhot rod Member Posts: 6,486
    30%
    glycol and 70%water. Ideally it should be de-mineralized water if you buy 100% glycol and blend it at the jobsite. You can purchase DE water or rent a filter to use at the jobsite to filter your source water. For large jobs requiring hundreds of gallons of blend water it might make sense to treat the water at the site, or buy drums of pre-mixed glycol.
    If a manufacturer of glycol knows how you are going to blend it they will inhibit it accordingly. So with a 30% glycol mix they would add more inhibitors, as one of the inhibitors job is to compensate for the blend water.
    Inhibitors buffer the ph, lock up hardness, film providers, O2 scavangers, color, etc.
    hr
    The magic is in hydronics, and hydronics is in me
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
