Evaporator coil failure
zeb2000_2
Member Posts: 9
Has anyone else been seeing a lot of evaporator coils leaking 1 to 5 years after installation? They are all R-410A and several other contractors are having the same problem. What is the cause of these failures? Acid? Thin walls?
coil failures
I have seen a lot of early coil life on home where the people burns a lot of scented candles,and all the spray that make the house smell good.
I remember when one of the leading company had many coil leaks due to enviroment they were put together in.
I have also herd that not performing a deep vaccum on that the non condensible were the cause.
Then its seem there has been time that the finn's were too tight and the expansion and contraction has gotten to them.0 -
Failurers
of evap coils on old construction or new const ? Chinese sheetrock ?0 -
The leaking coils we are seeing are all in existing homes- No new construction or remodeling.0 -
homeowner
My house was constructed in 2009. I have a lenox heat pump (R410) and the first evaporator failed after 2 years. The second evaporator failed after one year. The HVAC tech recommended the third evaporator get coated with electoFin to reduce corrosion. I said OK and we will see whether it helps.0 -
Leakers
I myself have replaced at least 10 evaps this year. The only manufacture I know that for sure has a production issue is Goodman. They have a prossess tube on their coils right on the suction line that is a crimp only no solder. I thought that the first one I saw leaking was a fluke. But I have made at least 3 repairs to that crimp and new coils I put in I solder them before install.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
