Steam radiators and hardwood floors
Rick49
Member Posts: 1
Has anyone had experience with raising old steam radiators in order to install new hardwood floors. I am installing 3/4" hardwood flooring in most of my house and am looking for ways to fit the flooring under the radiators. My brother had idea of double elbows (swing to adjust height) If I can get the pipes apart.
raising rads
yes have done it and seen it done disconet the radiator move out of the way put 3 foot wrench on pipe coming out of floor put block of wood under pipe handle step on wrench hadle see how much play you have0 -
I would remove the spud from the radiator
and use 2 street 45's to gain the height.Cost is what you spend , value is what you get.
cell # 413-841-6726
radiator
becomes conductive heater when it gets hot so tha cold air from the floor flows up thru the rad. If the rad is cooler than the room air, it might condense room air=? = mmight wanna put a pan under it0 -
Steam Radiators:
HUH???0 -
Ice some things are better
just ignored, I am sure Dan will edit out the stuff as it gets more off the wall.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
