condensate neatalizer
Dan C.
Member Posts: 248
What type of stones are used inside a condensate neatralizer? I want to start making my own and I don't know what to fill them with.
Crushed marble...
Home Depot, Lowes,
Enter from the bottom, exit from the top. Longer contact times equals better performance.
MEIt's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.0 -
Thanks.
That's what I thought. Wasn't sure though. Thanks.0 -
Forgot to mention....
While you're there, grab some copper sulphate (Root-X or equal). It keeps the fungal flora at bay (mold), and also keeps roots away from your sewer pipes :-)
I use to have a stoppage from roots in my main every year, but since I've started dosing it with the treated condensate from my modcon, I've not had to rooter the main in 4 years.
Also, depending upon your location, others have used diatomacious earth (sea shells) and or lime stone.
Neutraliser
Here is our home made neutraliser for several Armour AWN500. It is a "Rubbermaid" box that is filled with limestones.
Henry0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
