Tankless Natural Gas Hot Water Heater
Dave_23
Member Posts: 190
in Gas Heating
I'm in immediate need of a new natural gas hot water heater. My existing 50 gal conventional has failed. I'm considering both conventional and tankless. Any recommendations on brands: Such as Takagi, Rinnai, Bosch, Rheem (or others) for tankless; Not sure what's recommended these days for conventionals. I live in MI where the water temp in the winter can be in the 40 to 50 degree range.
Any suggestions are welcome.
I'll need at least a 50 gal conventional or probably a 199,000 Btu tankless.
Dave you will
find that the On Demand tankless will not give the GPM (gallon per minute) you are getting with the 50 gallon conventiaonal. It will in very cold weather, with cold ground water making up say 75 degrees that maybe you will get 3 to 5 GPM.
What do you heat with, if it is a gas or oil boiler and indirect would be an alternative to think about.0 -
Type of heating system
I heat with a WM EC series steam boiler. However, I don't run the boiler during the non-heating season (only the standing pilot burns)0 -
tankless gas water heaters
Take a look at Noritz NR98 199,000 btu input max delivers 4.5 GPM @ 75* F temp rise. most likely you will have to increase gas line.
A O Smith Vertex
Features
Continuous hot water, shower after shower! The more hot water you need, the more you need a Vertex water heater. Through an inspired blend of innovation, efficiency and years of industry expertise, A. O. Smith has created a family of state-of-the-art products that provide a long-lasting supply of hot water during those times when everyone in your home needs it most. Vertex™ power direct-vent gas water heaters take high-demand homes to the pinnacle of hot water availability. Vertex offers up to 96% thermal efficiency with performance that rivals much larger water heaters. With its fully-condensing design, Vertex delivers “continuous hot water” - shower after shower, hour after hour. Yet it’s easy to install, with dimensions and installation requirements comparable to standard power direct-vent units.- Unprecedented levels of performance - 96% thermal efficiency
- Continuous hot water - shower after shower, hour after hour
- An advanced internal heat exchanger with 100,000 BTU input, inspired by
A. O. Smith’s time-tested Cyclone commercial design - Easy to install - dimensions similar to a standard 50-gallon power vent water heater
- Eligible for Federal Tax Credit
[u][color=#0000ff]Click here to calculate your savings![/color][/u] The Great Spec Race
A. O. Smith announces an exclusive sponsorship with Allied Technical Services for inclusion into its online plumbing specification information system, which allows engineers to build plumbing specification systems, incorporating 3D software. Anyone can register at [u][color=#0000ff]www.atsspec.net[/color][/u]
View the results of The Great Spec Race - US Edition, Canadian Edition and ASPE Edition by [u][color=#0000ff]clicking here[/color][/u].Tech SpecsSpecificationsHigh Recovery:YesHigh Efficiency:YesVent:Power Direct VentEmissions:StandardGallon Capacity:50First Hour Delivery:164Recovery Rise @ 90°F (Gallons):129Vent Connection:2Tank Warranty:6 YearParts Warranty:6 YearInput BTU/HR Natural Gas:100000Water Connection Location:TopCarton Dimensions:30x25.8x74Vent Type/Material:PVC, CPVC or ABSWater Connections:3/4DimensionsWeight (Inches):255Diameter (Inches):22Height to the top of the Heater (Inches):66 3/4Rebates
Rebate and incentive programs provide cash-back to consumers for the purchase of appliances that meet certain energy efficiency standards. Often, these standards are tied to the ENERGY STAR® program.
Cash for Appliances is designed to encourage the purchase of energy efficient appliances. Consumers who purchase ENERGY STAR® or CEE qualified appliances can receive cash rebates. Most states are offering rebates in the $50 to $250 range.
Accessories
[color=#0000ff][u]iCOMM™ Elite Remote Monitoring [/u][/color]
[color=#0000ff][u]iCOMM Elite Brochure[/u][/color]
[u][color=#0000ff]iCOMM Spec Sheet[/color][/u]
- [color=#0000ff][u] [/u][/color]
[u][color=#0000ff]Vertex Family Video[/color][/u]
([u][color=#0000ff]Download[/color][/u])
To download this file, right-click the link, then click "Save As" from the menu.- [u][color=#0000ff]JPG[/color][/u]
- [u][color=#0000ff]PNG[/color][/u]
- [u][color=#0000ff]EPS[/color][/u]
- [u][color=#0000ff]Vertex™ 100 Series 120/121 GDHE Parts List (317454-000)[/color][/u]
- [u][color=#0000ff]Vertex™ 100 Power Direct-Vent (AOSRG45101)[/color][/u]
- [u][color=#0000ff]Vertex™ 100 Manual (197835-001)[/color][/u]
- [u][color=#0000ff]Vertex™ 100 Power Vent DV Manual (317443-002)[/color][/u]
- [u][color=#0000ff]Residential Annual Operating Costs (AOSRB63050)[/color][/u]
- [u][color=#0000ff]Vertex™ Family Direct Vent and Power Direct Vent Brochure (AOSRG01000)[/color][/u]
- [u][color=#0000ff]Vertex™ Family Consumer Brochure (AOSRG71000)[/color][/u]
- [u][color=#0000ff]Residential & Commercial Full Line Pocket Catalog (AOSAA80000)[/color][/u]
- [u][color=#0000ff]Residential Full Line Catalog (AOSRB80000)[/color][/u]
- [u][color=#0000ff]Ed Begley, Jr. and the Vertex™ 100[/color][/u]
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
