Primary Secondary with and On Demand Water Heater
Phelps_Clarke
Member Posts: 6
Is Primary Secondary a good Idea for piping an on demand water heater? Can I just use it like a boiler? what are the design considerations that I should be thinking about?
Not recommended.
An on demand water heater is not rated for use as a central heating appliance. We all have horror stories of trying to repair/replace "newer" installations, where the water heater can't perform. It is not designed to be used in that manner.
Most jurisdictions have outlawed their use as a central heating appliance. Meaning that it will not pass an inspection.
Don't do it. Get a real boiler. The gas mod/cons piped primary secondary will do the job as designed.
Good Luck.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
