Combustion analyzer help
Jim K_2
Member Posts: 2
Have a ten year old Bacharach Fyrite pro that keeps giving me trouble ( just serviced in Dec, now will not read stack temps) , want to upgrade. I test oil burners and gas equipment any ideas? Thanks
I use
The company I work for use's the Wohler. Excellent piece of eqipment, does everything and has stood up to 10 tech's using it..0 -
Combustion analyzers:
I hear the best about Wohlers and Testo 327's. They are field servicable and don't need to be sent back for repair and recalibration.0 -
Wohler hands down.
We have Wohler's and Testo's both. IMHO, the Wohler gives you quicker feedback to changes. The vacuum pump seems more rugged. The accessories, are a little pricier, but the performance is worth it.
Not a knock on the Testo at all. Both are top notch. Like comparing a Lexus to a Mercedes.
Good Luck.0 -
UEI
We have a UEI C50 and I have been extremely pleased with it. Very easy to use and seems quite rugged.
http://www.ueitest.com/product-c50.html
Rich L0 -
UEi50 UEi75
What features is the UEi units lacking vs the Testo 327 & Bacharach Fyrite Insight have? The UEi is a third of the price.:NYplumber:0 -
I had that cheap UEI.....
returned it after 1 month.... was not impressed. Just plain did not work right. #'s were way off.0 -
Jim
If the fyrite won't read stack temp, it might just be the wiring connection. Did you take apart the plug? I see this all the time as we have 50 125 Pro's. I've never seen a bad unit that causes this.
I've also seen where the other end of the probe is bad. In that case I just replace the probe/hose assembly.0 -
Have the thermocouple in the
probe replaced. Before doing so make sure it is not touching the inside of the metal probe.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
