What type of pipe insulation should be used on the near boiler piping?
<span style="font-size:12pt">What type of pipe insulation should be used on the near boiler piping, including the header, steam supplies and mains?</span>
<span style="font-size:12pt">How thick should it be?</span>
  • BobC
    BobC Member Posts: 5,520
    Pipe insulation.
    A minimum of 1" fiberglass pipe insulation should be used, more is better but expensive. All fittings should be insulated also.
    You can get it at a distributor or order it online.
    Bob
    3PSI gauge
  • crash2009
    crash2009 Member Posts: 1,478
    Insulation
    Glass fibre pipe wrap is used for the pipes and pvc with glass fibre inserts are used for the elbows and T's.  The names of 2 manufacturers are Fiberglass and John Mansfield.  For the pvc Covers Zeston and Speedline
    http://www.specjm.com/commercial/pipe/pipetankinsulation.asp
    http://www.speedlinepvc.com/smoke-safe-pvc
    http://www.specjm.com/products/pvcpipeaccessories/zeston2000.asp
    The most important place to insulate is the mains.  My basement used to be 120 F.  Now its a comfortable 70 F, the same as the rest of the house.  Also it makes the boiler quiet and the steam work better.  I dont even know when its running.
    I did my near boiler with 1".  The next time I would use 2".  It doesn't matter what it looks like but the pvc covers really give the job a finished look.  Here's a couple shots of how mine turned out.
  • gerry gill
    gerry gill Member Posts: 3,078
    these are pictures of our latest steam
    that the owner asked us to insulate..the fiberglass is 1'' to eventually mate up with the old asbestos..the fittings are covered with high temperature insulators cement..the whole thing is wrapped in scrim, (we use cheescloth), and then all is coated with childers mastic.
    gwgillplumbingandheating.com
  • TomM
    TomM Posts: 233
    white on red
    nice, looks trippy with the white pipes against the red walls.  or like an industrial newlywed suite or something.
  • Tradecraft
    Tradecraft Member Posts: 7
    Thank you for the advice.
    We'll follow your recommendations.  Thanks again.
  • Engr
    Engr Member Posts: 1
    Use Economical Insulation Thickness
    The insulation in our 12 unit condo was just installed in a project that my wife and I managed (we're both Engineers).  The software tool 3E Plus is very helpful in determining the best thickness to use for the best cost of install.
    The short answer of how much insulation to put on is: the most you can.  However, the more you put on, the more it will cost: thicker is $$$, thinner is $.
    The software lets you put all of your project info in (length, diameters, labor cost, fuel cost, expected lifetime of installation, etc) and comes out with the best bang for the buck. It's sponsored by our wonderful DOE, so it's free.
    http://www.pipeinsulation.org/pages_v4/details.html
