Cycling Evolutions?
NRT_Rob
Member Posts: 1,013
Anyone using Phoenix Evolutions or Solar evolutions seeing short cycling?
Have a contractor describing it to me during low load heating times. I suspect a sensor may be getting "spoofed" by low return temps from the heat exchanger.
This would be a major disappointment if it's a regular issue.
Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.
can you adjust the
differential on the control? maybe it is set too tight.
hrBob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
