taco rmb question
clammy
Member Posts: 3,111
i was wondering if taco radiant mixing blocks are avaiable with a plate exchanger i thought i saw that they where it would save me a bigger job of installing a plate exchanger i do realize that either way i would have to add a expansion tank feeder and all the stuff but i think it may be cheaper tahnks clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
NJ Master HVAC Lic.
Mahwah, NJ
Is their XPB close enough to your needs?
http://www.taco-hvac.com/en/products/X-Pump%20Block%99%20%28XPB%29/products.html?current_category=3740 -
Taco XPB
Expensive, but they save a lot of time.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
