Norton 271Q ignitors
bobdoss
Member Posts: 2
1. Does anyone know where I can find EXACT replacements for the Norton 271Q ignitor? Seems to be a real oddball, maybe used only by American Water Heater in its Polaris line.
2. Does anyone know if the 271A is physically and functionally identical to the 271Q except for the leads?
3. Does anyone have a phone number for Norton Tech Support?
Try the following
www,anericanationproducts.com/pdfs/anp2009_cross.pdf
I am not sure what is different about the Q version versus the A, many times it is only the wirng connector and that can be adapted simply by using wire nuts.
Also Robertshaw is the rep for Norton and the 41-405 igniter will replace the Q version of the 271.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
