Manual 3-way mixing valve
Jeff Perry_3
Jeff Perry_3 Member Posts: 102
I am doing a job and am using Danfoss/ESBE manual 3-way mixing valves on each radiant zone. Needed 4 valves and had exactly that many on the shelf. Went to go install them and 1 ended up being a 4-way. When I went to buy another 3-way I see that Danfoss has completely changed the style of their valves. The old number valve is an 065B8971 and the new number is a 193B1501. Now I could buy one of these, or a Tekmar or whatever but I am very much into the aesthetics of a job, as are most of you guys. Everything should be the same. Everthing should line up. If possible I would like to install the same valve. I can't find one anywhere.
Does anyone have a 3/4" 3-way ESBE they'll sell me or trade me. It's the old style that has the reversible metal plate under the knob and has 0-10 imprinted on it to show the proportional mixing.
I'd appreicate anyone's help.
Jeff
