Vacuum System Return
1234Paul
Does anyone know if its ok to insulate the return piping of a vacuum steam system? I've heard that hot condensate can destroy vacuum pumps.
It is usually not worth the cost as the returns
often are not that warm. Cooler water is better as it reduces the chance of cavitation. When water is near boiling the suction can lower the boiling point to the point where it flashes to steam in the impeller housing.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
