Logamatic Setting Questions for Buderus - Curves Very Low
K239
Member Posts: 1
<span style="font-size:12pt">I was wondering if someone could review the settings on my Logimatic, as our Buderus Boiler/HWH seems to be operating inefficiently. Gas usage in summer is at $300/month and winter at about $900/month. This seems very high. Also, curves have very low numbers (see below)</span>
<span style="font-size:12pt"> </span>
<span style="font-size:12pt">System has LT-300 HWH, G334X/73 Boiler, Logimatic R 2107 and outside thermostat. It has one circuit, single pump, and no room sensor. House is 7,000 square foot two story ranch house in Westchester NY (north of NYC). Heating is primarily Slant Fin baseboard (7 zones) and one air handler (hydro air) located adjacent to the boiler. House is wood construction with good insulation.</span>
<span style="font-size:12pt">Logimatic is set at automatic, using the “Family” setting. At present, recirculation is set at 3x. We like piping hot water for bath and pot filling. Someone is usually in the house 24/7.</span>
<span style="text-decoration:underline;"><span style="font-size:12pt">We would like to know the ideal, efficient settings for the Logimatic and, if applicable, boiler & HWH. If relevant, would like to know for each season.</span></span>
<span style="font-size:12pt">Three items of note:</span>
<span style="font-size:12pt">1.</span> <span style="font-size:12pt">In summer, the boiler temperature during the “day” hours is usually at 176.</span>
<span style="font-size:12pt">2.</span> <span style="font-size:12pt">Often the boiler temperature as measured by the Logimatic is 20 -30 degrees different from the temperature as shown on the gage of the boiler.</span>
<span style="font-size:12pt">3.</span> <span style="font-size:12pt">Please take particular note of the heating curve numbers at the bottom, and the reference and offset temperature setting.</span>
<span style="font-size:12pt">These are the settings:</span>
<span style="font-size:12pt">DHW: 140 degrees, set to “auto” (factory setting)</span>
<span style="font-size:12pt">WWSD: 73 degrees (factory setting is 63)</span>
<span style="font-size:12pt">Heating Program: Family (factory setting)</span>
<span style="font-size:12pt">Boiler</span>
<span style="font-size:12pt"> Freeze Temp: 41 degrees (factory setting)</span>
<span style="font-size:12pt"> Bldg Resp: 1 (factory setting is 2)</span>
<span style="font-size:12pt"> Pump Logic: 104 (factory setting)</span>
<span style="font-size:12pt"> Max Temp 176 (factory setting)</span>
<span style="font-size:12pt">Circuit 01</span>
<span style="font-size:12pt"> Ref Temp: 176 (factory setting is 167)</span>
<span style="font-size:12pt"> Remote 1: off (factory setting)</span>
<span style="font-size:12pt"> Setback (recommended setting)</span>
<span style="font-size:12pt"> Offset: 0 (factory setting)</span>
<span style="font-size:12pt">NOTE HERE THAT WE HAVE BOTH AIR HANDLER AND RADIATORS, AND APPLICATIONS MANUAL SUGGESTS 0 DEGREE OFFSET FOR RADIATORS, AND 9 DEGREES FOR AIR HANDLERS</span>
<span style="font-size:12pt">DHW Prod: On (factory setting)</span>
<span style="font-size:12pt">Recirc Pump: 3 (factory setting is 2)</span>
<span style="font-size:12pt">Htg Curve: 43, 50 degree (the example given shows 113) THESE SEEM WAY OFF</span>
<span style="font-size:12pt"> 43, 32 degree (the example given shows 145) THESE SEEM WAY OFF</span>
<span style="font-size:12pt"> 77, 14 degree (the example given shows 167) THESE SEEM WAY OFF</span>
<span style="font-size:12pt">Version: 400</span>
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
