Heat Loss Program
Member Posts: 4,011
I relied on my copy of the Slant/Fin heat loss program that I had for years and now I have a new computer with a new operating system (Windows 7). I'll be trying to move it over, but in the event that I can't, does anyone know of an equal? It was easy to use and FREE!
not free, but very
affordable. This ids the heat load program that Siggy built. I like the wall input screen. It allows you to build up any wall including basements with different bury depths, etc. www.hydronicpros.com
hrBob "hot rod" Rohr
Living the hydronic dream0 -
HVAC Calc
I bought this program and it is easy to use. It is called HVAC Calc located in Michigan.0 -
I believe Upinor has one.
I had one installed in my laptop which has since crashed and I have not re downloaded it. Check their site. It is FREE!There was an error rendering this rich post.
Heat Loss Program
Thanks, guys. That helps.
I have since been able to start my computer in "XP mode" and salvage my Slant/Fin program. In time, I'll upgrade.
All the best,
Alan8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
