Heat Pump for Unico System
MacPHJr
Member Posts: 66
I'm looking for a good heat pump that works well with the Unico Air Handlers. Any preferences?
unico heat pump
i dont have any preference,we use lennox.Whatever brand condenser you use, make sure your airflow is ok,at least 7 outlets per ton,static 1.5'wc,or else in heating mode you will have nuisance hi press lockouts.0 -
unico heat pump
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
