real estate management
howire
Member Posts: 1
in Oil Heating
building next door whle under construction violated chimney. Cracked chimney liner, both buildings share a common wall where the chimney is located. The building has a 8 inch flue going out of the chimney into a 4 inch chimney flue. . The burner is a Beckett model afg which burns 1.75-2.50 p/h. What is the best way to repair the chimney? Place a insert in the chimney or run a new flue pipe hrough the basement to the back of the building and up four stories. About a 75 foot run from the boiler room.
flue size
You should bring in a couple of chimney companies and compare their advise. A 4" flue is a little small for that nozzle sizes you mentioned,0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
