Main vent piping
Sizzlaw
Member Posts: 11
I am adding two vents to my one-pipe steam system. The piping from the main to the vents is 16 inches long and I can use either 3/4 or 1/2 inch pipe to connect to the vents (the vents are equipped with both size threads). Is there any advantage favoring one size over the other?
what are
the vents your planning on using?gwgillplumbingandheating.com
Venting
Go large.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
