Baseboard heat tubing
tkm55
Member Posts: 1
I have baseboard heat and the pipe comes out of the baseboard up the outside of the wall around the room down the wall then into the heater closet can I change it to pex and run it throught the wall and throught the floor joints then down the wall into the heater room and if so what size hole do I need to drill and should I use an elbow for each bend???
thanks
TIm
thanks
TIm
Why not
Just make sure you use barrier pex and drill your holes so your pipe insulator will fit. .0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
