700 auto air vent
joebear
Member Posts: 2
when using 700 auto air vents,does the cap need to be loose to vent air or can air be vented with cap closed?
700 auto air vent
I must be tired,,,,, who makes that?0 -
700 auto air vent
amtrol0 -
Depends
The older models with the schrader valve , the cap needs to push down on the pin just a little vent out the air .. The schrader valve was a secondary valve ... Seems like they added the schrader as a safety valve ...Cap fully closed , open or missing the vent is closed ....
i cut one apart years ago when this question came up ...
In the newer models the schrader seem to be deleted ...
Second note.... From inside their paper work , you should set the cap just slightly loose . They don't want a rush of air, water and dirt to foul the valve seats ...There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
