Hydro level pump control probes
hvacman1028
Member Posts: 4
Installed V7, V6 Burnhams last winter for church and small Parish Hall. Boilers work great, heat perfectly, have feed tank with pump. LWCO probe type with manual reset. Installed 2 Hydrolevels for 24 volt pump control. Probes constantly getting fouled. Flushed return lines out, treated with chemicals, skimmed boiler prior to startup, no surging, no foaming, no problems other than probes get fouled, then they dont call for pump, trips on LWCO. Arrive on site, pull probes, clean them, boilers run for about 30 days, cycle repeats....any thoughts as to where the sludge is coming from??? Only 1 line buried for about 20 ft, it was replaced 5 yrs ago. Flushed that line prior to start up last year. Could it be in the rads??? Dont believe so, but running out of time....thanks
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
