hotwaterheat
connie
Member Posts: 2
what is the flow rate for half inch pex when applied to a conventional boiler with convectors
It depends....
on NUMEROUS variables, like pump size and pipe length.
A general guide is to limit the flow in a 1/2" pipe to less than 2 GPM, preferably more like 1.5 GPM.
At a 20 degree F differential in temperature, that flow would deliver 15,000 btuH to a properly sized heat emitter.
MEIt's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
