Electric Water Heater along with Gas Boiler for radiant heat
FunStuff
Member Posts: 1
I have a propane boiler that heats both domestic and in floor heat. I am looking for a diagram showing how I can hook up a standard electric water heater along with my system. I am also looking at hooking up a solar panel and storage tank and need diagrams to hook it into my system as well so as to make the whole more versatile and economical.
Thanks,
James
Thanks,
James
Why wouldja wanna do that?
Natural gas has always been the lesser expensive of the two heat sources from an operating stand point.
Is this so you can fill a larger tub or take more showers?
In any case, the solar pre heat is always first, then gas, then lastly electric.
Piped in series.
Don't forget to provide hot water protection between the solar pre heat and the auxilliary heat sources and between them and the final load (anti scald).
METhere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
