Horsepower per Ton Question
PCBOILERMAN
Member Posts: 11
The horsepower per ton of a unit is .60. If the horsepower increases by 20% while the refrigeration effect decreases by 10%, what would the horsepower per ton be?
Maybe
I'm not a math whiz. I get .792 H.P. per Ton (12000 btuh). I would not
trust this number with out corroboration.bob0 -
You are correct Bob
12,000 BTU/hr = 2000 BTU/HR = 7.85 HP/TON x .10 = .785 or .8
.60 HP/TON 2,545 BTU/HR/HP
1TON = 12,000 BTU/HR
1 HP = 2,545 BTU/HR
This is how I figured it out but I wanted to see if someone else would get a similar answer. Thanks!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
