radiant wood heat questions
woodheatguy
Member Posts: 7
My question concerns a wood stove radiant heat set up.
If you would look at the attached diagram and let me know if
there is a better way to plumb it?
The hot water heaters are used just for storage. (I found
them on the side of the road)
Specific questions:
1. Should I have a heat trap on the return line from the
floor loops ?
2. Should I connect all the tanks to the makeup water? And
should there be a heat trap in the makeup line?
3. Would it be better to run the circulator pump off the “hot”
line from the wood stove? When the pump is running I tend to get a little bit
of banging from the thermo siphon.
Any suggestions anyone would have would be great.
Thanks again,
Woodheat Guy.
Specific questions:
floor loops ?
Thanks again,
Woodheat Guy.
Woodheat Guy
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
