viessmann
tekmar
Member Posts: 8
in Oil Heating
just bought a viessmann vitorond vr-21 with a riello burner and a indirect hot water heater no smart control for boiler yet $$$ it came with the honeywell control l8148 what would be the best settings on this control any help thanks
Minimum Water Temp
The iron can handle a minimum water temp of 120 without the injector that is put in at the factory when purchased with Vitotroinic Control. Just make sure you don;t condense the chimminey. Can't tell you where high limit needs to be. I don;t know the heat loss of each zone or the emitters. Are you zoning the boiler with priority? If so, whose zone controls. If your going to use a Taco just make sure it's and EXP version and you can add the PC701 for boiler reset down the line.There was an error rendering this rich post.
Hey, I wanna Viessmann
Wherejachet that fancy little toy? Imma lookin' fer a deal myself, but can't find one.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
