This is the question of the day.
stretch
Member Posts: 6
What do you think about taking the flue pipe through the plenum (80%) for the extra heat off the pipe. What would you guys tell the customer????
I wouldn't do that
it will cause the flue gases to condense in the flue pipe and chimney. This can cause many problems.All Steamed Up, Inc.
Consulting0 -
Well
I don't think you would loose that much heat from the flue, unless things were marginal to begin with. And I don't think there would be any real gain to the outlet air temp. But I do know that if there was a problem with that pipe the possibility exists to put exhaust gasses into the house, and that would be very bad. Don't do it!0 -
flue
Years ago on some basement model furnaces the manufacturers used to run the flue through the blower compartment. Sometimes they even made attempts to increase the surface area of the flue. Not a good practice. Lots of failures and the flue gasses go right into the air stream.bob0 -
Bad Idea
Illegal and forbidden by all mechanical codes!!0 -
Of course
Low boys with rear flue are set up that way, but they are a fairly substantial piece of metal. Then again, I've seen plenty of Carrier low boys/rear flue that are anything but substantial and are rotted away.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
