Prestige with Alpha pump
Nathan_G
Member Posts: 1
Getting ready to install a Prestige Solo 110 in a house with CI rads. Ignoring the rad sizes and doing the heat loss, it needs 90k BTU. It has 6 zones on it and some appear to be fairly small. I prefer to not primary/secondary pipe. I don't know the head of the system and am wanting to use an Alpha pump. From what I have read about the European installs, the variable speed pumps are a no go with a Mod Con but I have also read the Prestige is OK
The real question is, can I replace the pump in the Prestige with an Alpha or is this only for the secondary side of PS?
Nathan
Nathan
well
I have no idea how you'll get an outlet wired into the cabinet of the solo, but the other trick is you would have to maintain the minimum flow rate requirement for the solo. that can be hard to ensure with "autoadapt" but with fixed pressure and adequately large minimum zones or pressure bypasses it can be done.
I would question the wisdom of it though. If you can do the whole system with one pump and it has to be fixed speed, that's not a bad place to be.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
