flame makes a loud blowing noise
Joseph_4
Member Posts: 271
in Gas Heating
Today I was working on an old Liberty Combustion Corp model 150 sc gas type burner. There is a loud blowing noise as the gas burns. I observed the flame for a while and it seems to be burning only where it is suppossed to. Can someone tell me if this is a concern. I once had the same kind of noise on a manifold type gas boiler and the noise was from the flame burning inside the steel manifold tube. What causes it. Thanks. How can I correct it?
I believe that
is a inshot monoport burner, they do tend to roar a little bit when running so that is normal for that type burner. Try reducing the primary air slightly and see if it softens up.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
