Thermostat for Hot Yoga Room
Paul Pollets
Member Posts: 3,656
Does anyone know of a 2 wire T-stat that will go to 105-110 degrees F ?
This would be for heating a hot yoga room (820SF), to 105-110 at 24 degree design. The design calls for wall panel radiators mounted at the ceiling and a mod con boiler. I'm trying to convince them to put the rads under the windows, not on top.
hot stuff
would a sauna thermostat work, or even a complete sauna setup?--nbc0 -
Do you mean something like this?
http://www.globalspec.com/FeaturedProducts/Detail/Stego/ET_011_DC_24_V_Electronic_Thermostat/27083/0
60C is about 140F.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
